It is currently Tue Jul 22, 2025 12:19 pm
PostPosted: Sun Mar 04, 2007 3:14 am
I'll be watching this with great interest.
PostPosted: Sun Mar 04, 2007 8:08 am
I'm facing the same problem. Help me, help me!!!
PostPosted: Sun Mar 04, 2007 10:34 am
are you referring to the jig or the routing template?
if it is the templates you refer to and you have the measurements to do them by hand there is no reason you can't reverse engineer the templates from acrylic. or i could route copies if you like.
PostPosted: Sun Mar 04, 2007 1:10 pm
Back in '84, I built an archtop with a dovetail neck joint, and I had no info on any of the construction of it, because it wasn't there, so what I did, was get a standard dovetail bit, used a collar on the router, and made a jig to cut the slot in the body. Then, I layed out on the neck, the cut, and did it by hand, and it didn't take too long to do. I'm not even going to tell you how I carved the top and back, because it's pretty funny. Alan
PostPosted: Sun Mar 04, 2007 1:56 pm
Michael, Sorry I haven't checked this thread. I use a somewhat different approach, my templates are wooden, maple and walnut. Also, I use a Router table and move the jigs through the router, completely different than anyone else I've ever seen cut dovetails. But it works for me. Maybe I can scare up a pic, but you might be better off spending the $75, as I agonized for days getting mine perfected. And, I like you, can do a dovetail now in 1 1/2 hours rather than much more on my first few.
PostPosted: Sun Mar 04, 2007 7:16 pm
Michael,
I've got some plexi templates & a jig if you want to come out & copy it. Let me know, I'll have to dig them out.
GD
PostPosted: Mon Mar 05, 2007 1:51 am
PostPosted: Mon Mar 05, 2007 2:07 am
Aside from tradition, are there any structural or sonic advantages for using the dovetail that you guys see over the bolted M&T joint?
From the start, I've taken the easy M&T path but I'm interested in considering this approach.
PostPosted: Mon Mar 05, 2007 2:17 am
Bruce, I also use a router table to cut dovetails. When you look at the setup, it makes a lot of sense. One advantage is you can see the cut better since the bit is pointing up.
PostPosted: Mon Mar 05, 2007 4:17 am
Barry, I feel true kinship with you.... grin....
No kidding, I have no clue why I went with moveable routing jigs rather than moving the router through stationary jigs, but it works.
I do like the ability to see most of the action. Also, I'm wondering if you make multiple cuts as I do, with a secondary straight bit to do the hogging of the majority of the wood? I had trouble with bits flying out of the router before going to step-cuts then a final pass with the dovetail. It's too much for my setup to remove at once.
I sure like the looks of Woolson's jig, it just looks smart.
JJ, why dovetail? I just wanted to follow my heroes Charlie Hoffman and Jim Olson. I felt if it was good enough for them, it was a good option. But I certainly see the wisdom in M and T, and doubt there is much difference in sound transference. It is cool too to find George Lowden still dovetailing after all these years. I think old habits are hard to break, plus, you don't have to retool....
Users browsing this forum: Bing [Bot] and 15 guests
